LT1/LT4 Tech 1993-1997
help buld my 94z
Old 09-10-2011, 03:01 PM
sgtdupree's Avatar
I unbolted my headers from the head but do I need to completely take the headers out to get to the bolts on the head below the headers. hopw not my exhaust is welded to my headers.
  #62
Old 09-10-2011, 08:31 PM
torque_is_good's Avatar
Originally Posted by sgtdupree
do I need new head bolts everytime I remove the heads. what bolts do u recommend
1: if you are getting rid of the car, no. it is good practice to replace them because removing heads isn't a common thing to do
2: what flavor ice cream do you like? be prepared for opinions.
  #63
Old 09-10-2011, 11:11 PM
yes you do. the head bolts are torque to yield. they stretch when torqued. you may get away with using them over then again you may not.
  #64
Old 09-12-2011, 11:38 AM
sgtdupree's Avatar
did you guys with LT headers have to get ya diver side header bent. the end of my header where the exhaust meets touchs the bottom of the car. when i cut them off to replace my head gasket ima put collectors on like i shoulda to begin with. but with it touchin on the bottom i think ima have to get the header bent to make it work.
  #65
Old 09-12-2011, 12:00 PM
kooks fit fine. the y pipe was a challange.
  #66
Old 09-12-2011, 01:54 PM
sgtdupree's Avatar
I got pacesetters and they don't. it's gonna need some
tweekin to use collectors
  #67
Old 09-13-2011, 02:27 AM
suembeaux's Avatar
what was the mileage on the car when you started all this? I'm planning on doing something similar with the same engine and I want to know if any problems could have come from poor maintenance in the past. I'm trying to find out as much as I possibly can before I dump any money into anything.
  #68
Old 09-13-2011, 06:38 AM
sgtdupree's Avatar
mine got about 174xxx but it ran fine before I started messin with it. I'm findin out this stuff ain't really that hard and can b done in a day. my hiccup is not knowing obvious stuff and not havin the the tools. I got the Hayes manual its makin things all easier as far as disasemble and reassemble. idk much bout what parts r good to upgrade to so I jus go offa the info I get from here.
  #69
Old 09-13-2011, 01:20 PM
sgtdupree's Avatar
do I need a special tool to remove the water transfer tub that connects to the back of two heads. the book says it's a banjo bolt????
  #70
Old 09-13-2011, 01:22 PM
sgtdupree's Avatar
never mind. I c what a banjo bolt is now.
