LT1/LT4 Tech 1993-1997
Grind in 1st and 2nd gears
Old May 26, 2010 | 04:28 PM
MeggyD's Avatar
Default Grind in 1st and 2nd gears
Hello all. I'm new to the forum and have been the proud owner of a 94 LT1 for the last 3 months.
There's a grind especially in 1st gear. It happens mostly when I'm trying to give it some power, like maybe pulling into traffic on an uphill start. Admittedly, this IS my first manual tranny vehicle, but we're not talking about the beginner-manual driver kind of grind. As a matter of fact, I've learned to drive it in a way that the grind doesn't happen by babying it on starts, which kind of takes the fun out of owning a manual V8. It happens more to my experienced manual driving friends.
The common consensus among my informed friends is that it is linkage/synchro problem. If so, is this something I'm gonna need a whole new tranny for or is it something that can be patched up?
I got it for a steal, even though there's the tranny problem, I have a broken compressor (and it's gettin' HOT in NOLA), and the ragtop leaks.
Thanks
Old May 26, 2010 | 05:49 PM
so it grinds when you try to put it in gear? or after its in gear and you give it gas? is the grinding coming from the rear of the car? can u feel it in the shifter, clutch peddle, seat of pants?
Old May 26, 2010 | 06:13 PM
MeggyD's Avatar
It grinds after it's in gear and I give it gas. It feels like it's coming from the front of the car. I can feel more in the clutch than the shifter or seat.
Old May 26, 2010 | 06:38 PM
does the car slow down or jump when it grinds? im trying to figure if its really in the trany or something like a mount.
Old May 26, 2010 | 06:49 PM
"If you can't fine em, grind em"!
Any chance you're feeling clutch chatter? Or maybe a bad mount making the trans go hippity-hop to the repair shop?
Old May 26, 2010 | 06:54 PM
MeggyD's Avatar
I wouldn't say it jumps when it grinds. I should clarify that the grind is a bit more of a 'moaning' sound.
One friend DID mention that it might be some loose mountings.
Old May 26, 2010 | 06:57 PM
MeggyD's Avatar
It's a grinding sensation through the clutch though
Old May 26, 2010 | 06:59 PM
Bad throwout bearing...perhaps.
Old May 26, 2010 | 07:05 PM
yep may be a good idea to take the inspection cover off if it has one and have a look at the clutch and throwout bearing. im thinking the pressure plate is getting weak or a spring or two may have busted.
Old May 26, 2010 | 07:14 PM
MeggyD's Avatar
The service records didn't show where the clutch had ever been replaced and it IS a 16 y/o vehicle.
I'm just trying to get a rough idea how much this problem is gonna set me back before I take it in.
Thanks
CaCruiser
Oct 22, 2014 06:33 PM
9434V6
Aug 26, 2011 09:32 AM
ESPxCONxXx
LS Series Tech
Jan 4, 2010 06:46 PM
NomadicZ28
Jan 23, 2007 04:41 AM
