LT1/LT4 Tech 1993-1997
exhasut manifold question
Old Mar 15, 2012 | 04:39 PM
borjawil's Avatar
Default exhasut manifold question
Ok so when removing exhaust to replace head gaskets the 3 bolts that connect the manifolds to the Y pipe broke from being so rusted. So I drilled them out but since there is little room I cannot grab both sides of the bolt in order to tighten. Sooo I was thinking of welding the bolts to the manifold but im not sure what it is made of. Im thinking cast iron but if not let me know.
Also if thats not an option what years manifold will swap on to a 94 LT1? 5.7l
Old Mar 15, 2012 | 05:09 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
They are cast iron I believe.
Old Mar 15, 2012 | 07:14 PM
borjawil's Avatar
ok well either way im using the coil/thread insert things. You drill out the old thread/hole then tap it and insert a threaded spacer thing that is thread inside and out.
Old Mar 16, 2012 | 12:12 AM
yep its that or another manifold. i have a 93 set if it dosent work. i think 93 and 94 are the same. not completely sure. if you have a pipe going from the passenger side exhaust to the intake manifold it would not be the same as a 93 but a 95 to 97, they should be same.
Old Mar 16, 2012 | 07:49 AM
borjawil's Avatar
yep I have the egr pipe i believe it is going from the passenger manifold to the intake. Good to know. Hopefully the thread insert works though.
Old Mar 16, 2012 | 08:28 AM
Once you get the heli-coils in, look into using the replacement manifold studs instead of bolts. And if you use brass nuts to hold the flanges, you'll be able to get them off again easier if you wanted to later. Get the "tall" nuts if you can. And.....Anti-Seize everything.
Old Mar 17, 2012 | 08:53 AM
borjawil's Avatar
I was going to use some thread lock. Guessing you cant use anti seize and thread lock together. Just use the anti seize and torque em?
Old Mar 17, 2012 | 09:16 AM
You can do it that way too if you want, thread lock will act as a thread protector. Don't use the red, and see if you can find the high temp version. But honestly, I've never had a flange nut rattle loose, but I do like to use lock washers. Weather, time, and temperature seems to bind the threads pretty well on it's own, even with using anti seize.
Old Mar 17, 2012 | 02:24 PM
borjawil's Avatar
why shouldnt i use the red? and There arent any flange nuts. the heli coils are in the manifolds and bolts going through the clamp to them.
Old Mar 17, 2012 | 04:13 PM
Red is a permanent locker, also makes it harder to get things back off if you need to. Blue is made to be used with 1/4"-3/4" bolts, red is for 3/8"-1" bolts.
I was saying nuts, not being sure if you were taking my stud instead of bolt recommendation.
JakeYeah
Nov 14, 2012 01:44 PM
97blackcamaroRS
Dec 6, 2010 03:57 PM
timmyz28
May 13, 2010 03:05 AM
Unit94Z28
Aug 16, 2009 03:07 PM
superROB23
Apr 24, 2006 02:04 AM
