LT1/LT4 Tech 1993-1997
Exhasut Question...
Old Aug 16, 2009 | 02:45 PM
Unit94Z28's Avatar
Default Exhasut Question...
ok so im taking my cat off and I am going to be replacing it with a straight pipe. I need to know the diameter of the pipe coming into the cat as well as out. If anyone has done this and knows the exact distance that would help too.
Thanks
Old Aug 16, 2009 | 03:07 PM
dopez28's Avatar
well you can either do that of just undo the exhaust out behind the cat and bust the cat out. thats what i did on mine. incase you need a cat for inspections. some inspectors look for that. some dont. but i believe the pipe is a 3 inch pipe. and the length all depends on where you cut it at.
JakeYeah
Nov 14, 2012 01:44 PM
JPrice
May 20, 2012 03:48 PM
borjawil
Mar 17, 2012 04:13 PM
endo
Sep 30, 2010 12:51 AM
superROB23
Apr 24, 2006 02:04 AM
