LT1 Intake Manifold Question
Old May 6, 2010 | 07:50 PM
timmyz28's Avatar
Default LT1 Intake Manifold Question
Will an LT4 intake bolt up to stock lt1 heads? I've heard so many different things, and I'm not sure what to believe.
Old May 6, 2010 | 09:02 PM
whammer3024's Avatar
ROTM Winner
no it will not. you will need to find lt4 heads to be able to use the lt4 intake
Old May 7, 2010 | 02:13 AM
95slvrZ28's Avatar
Replacing the LT1 intake manifold isn't going to get you much anyway. The LT4 intake just had slightly taller ports to match those of the LT4 heads. It would only be an upgrade if you consider "red" and upgrade.
BTW...What's up Wham
Old May 7, 2010 | 08:02 AM
ROTM Winner
wow...slvr is back! finally! just been holdin down there fort in your absence!
if you already have an lt4 intake and are wanting to use it, we can help you find lt4 heads if you want
Old May 7, 2010 | 10:41 AM
timmyz28's Avatar
i didnt buy them yet. i'll look into it more cus i dont have the money for heads right now. any other performance ideas though would really be appreciated
Old May 7, 2010 | 10:55 AM
ROTM Winner
what do you have done already?
Old May 7, 2010 | 12:58 PM
95slvrZ28's Avatar
Yeah, I'm finally done with school for the semester, so I have "free time" again.
Timmy: If I were you I'd look at some better options than the LT4 stuff. You can get significantly more power for the same amount of money if you look elsewhere. That said you need to make sure you have the correct bolt-ons before you start looking into internal components.
Old May 11, 2010 | 08:32 PM
timmyz28's Avatar
I have full exhaust (bbk shorties, high flows, glasspacks), cold air intake, just got its 1st full tune up (plugs, wires, etc), msd ignition, and chipped.
Old May 11, 2010 | 08:55 PM
ROTM Winner
gears. if you're auto you will wanna look into a torque converter
Old May 11, 2010 | 08:56 PM
timmyz28's Avatar
yeah it is auto. what type of converter should i look into? what about a shift kit? what gears?
