LT1/LT4 Tech 1993-1997
Door Panels (i.e. Window Crank)
Old Jun 12, 2006 | 06:43 PM
t_jnorth's Avatar
Default Door Panels (i.e. Window Crank)
Can someone please explain to me how to get the door panel off my 1998 Chevy Camaro. I just bought it and I'm trying to troubleshoot the speakers in the doors because they are not working. I can get everything off the door except the Window Crank. HOW DO I GET THAT CRANK OFF????
Old Jun 13, 2006 | 02:13 PM
Default RE: Door Panels (i.e. Window Crank)
The handle is held on to the shaft with a clip, You ned to insert a tool between the handle and the spacer to release the clip. The tool is J 9886-01, but you can find a universal tool at most auto stores. Basically a flat knife blade with a notch in the center that goes around the handle shaft.
CheVy_R0aRrR
Jun 8, 2011 01:39 AM
germ89
LS Series Tech
Nov 6, 2009 09:03 PM
GoofieJ21
Jan 13, 2008 09:45 AM
350rs
Jan 8, 2008 10:43 PM
t_jnorth
Jun 12, 2006 04:05 PM
