So I have a crank door and an electric door!
Old Jun 7, 2011 | 01:19 PM
CheVy_R0aRrR's Avatar
Default So I have a crank door and an electric door!
Ok my car is a rebuilt title.I always knew my passenger door was replaced because of the interior trim.However my car is base and is all manual.The passenger tho had a hole as to where the window crank would go.I further inspectioned and i found it weird when I sticked my finger inside the hole to not feel anything around.Im like damn now I gotta go to the junk and get me the rear mechanical system.
Well yesterday,I decided to paint my interior trim piece in red to give it some life.So as im removing the panel plastic where the door lever and lock are I see a bunch of cables .... As I look inside and im like damn snaps this is an electric door bummers!!!
I've really being hating the fact I can't lower my window in this florida weather,not because its hot but because I love "free air"(lol.) So fellas is there a way I can get the power window to work? Im kinda pissed, was really looking forward to getting that window down asap.
Old Jun 7, 2011 | 03:10 PM
3800camaro's Avatar
Go to the junk yard and grab a manual door and swap the guts out. To get a power door to work is a pain in the ***. Alot of wiring to do that.
Old Jun 7, 2011 | 06:19 PM
Dana's Avatar
How difficult is it to take your power door out and put in a manual? My husband has threatened to do that to mine since my window needs some work. I'm getting it painted in a few months anyway.
Old Jun 7, 2011 | 08:06 PM
3800camaro's Avatar
Why would you want to go from power to manual? If everything is connected and works then leave it. If it doesn't work it's most likely a fuse or motor.
Going from a manual to power is more of a pain then just swapping the guts of the door.
Old Jun 7, 2011 | 08:51 PM
Dana's Avatar
Hubby said it would be easier to change the door than to bother trying to get to the motor in the window. It was working perfectly fine going down and then when I went to roll it back, not a sound out of it. I prefer the manual windows now. We have half of our cars needing power windows worked on.
Old Jun 8, 2011 | 01:30 AM
Yup Ima have to do this...How much is a fair price for a door with gutted door panels? Cause the junkyard I go to that has these f-bodies the cars are so stripped its ridiculous.So a door missing the panels can't really be worth more than $70 bucks imo lol...
Old Jun 8, 2011 | 01:39 AM
Alright well if its not the control module,fuse or relay than I want you to give this a try.Im optimistic it might work.Gave results on 2 stangs I owned! (Just don't tell anyone here I had ponies LoL!)
Directly to matter,So yea well at the bottom of the door right around the middle,give it about 3 mild side punches and flick that switch. Worked like a charm on these and them motors were perfect. Learned this trick from an old dog, it happens and can happen to any car. Mechanism just jams,so those mild knocks make it snap out of it by unjamming it. Pretty cool stuff, hopefully this helped ya out!
PEESKI
May 11, 2012 11:19 PM
Mikey.
Oct 19, 2011 12:19 AM
bradellis6223
Dec 21, 2009 04:01 AM
t_jnorth
Jun 13, 2006 02:13 PM
t_jnorth
Jun 12, 2006 04:05 PM
