Door Sag
Old Oct 17, 2011 | 08:38 PM
Mikey.'s Avatar
Default Door Sag
Hey guys. I'm having a problem with my drivers side door sagging a bit. It's to the point where it touches the fender when I open it and I hear a pop. I also have to pull the door shut pretty hard for it to latch. When I shut the door it straightens out, and as soon as I open it she drops. Do I need to replace the hinges, and if so where abouts can I get some new ones?
Old Oct 17, 2011 | 11:06 PM
iLL95's Avatar
I Like to Party
Super Member
From how your describing it it sounds like the same problem on my passenger side.when you close it does it take some force?I'm starting to get annoyed with it.
Old Oct 18, 2011 | 12:10 AM
BasicConcepts's Avatar
Technical User
its the pins and bushings in the hinges... there pretty easy to replace
first take off the door panel and unhook all the wiring and pull it out of the door
then unbolt the door and put it aside
grind off the top of the pin and use a screwdriver and hammer to get it out of the hinge
press the new bushings in with a clamp
install the new pin and secure with the supplied clip
bolt the door back on and get the wiring all back together along with the panel
enjoy you nice smooth moving door
ive done probably 50 doors there pretty easy id say a 3 out of 10 maybe 45 min per door for a novice mechanic
ohh you may wanna replace the strikers too as they wear with a sagging door
Old Oct 18, 2011 | 10:16 PM
Mikey.'s Avatar
Any idea where to get the parts? I can't find the hinges themselves let alone a rebuild kit.
Old Oct 19, 2011 | 12:19 AM
Technical User
you can find them right here
PEESKI
May 11, 2012 11:19 PM
CheVy_R0aRrR
Jun 8, 2011 01:39 AM
EZST70
LS Series Tech
Feb 18, 2010 04:19 PM
bradellis6223
Dec 21, 2009 04:01 AM
MotoFreak195
Oct 31, 2007 01:55 PM
