Door Sag
Hey guys. I'm having a problem with my drivers side door sagging a bit. It's to the point where it touches the fender when I open it and I hear a pop. I also have to pull the door shut pretty hard for it to latch. When I shut the door it straightens out, and as soon as I open it she drops. Do I need to replace the hinges, and if so where abouts can I get some new ones?
From how your describing it it sounds like the same problem on my passenger side.when you close it does it take some force?I'm starting to get annoyed with it.
its the pins and bushings in the hinges... there pretty easy to replace
first take off the door panel and unhook all the wiring and pull it out of the door then unbolt the door and put it aside grind off the top of the pin and use a screwdriver and hammer to get it out of the hinge press the new bushings in with a clamp install the new pin and secure with the supplied clip bolt the door back on and get the wiring all back together along with the panel enjoy you nice smooth moving door ive done probably 50 doors there pretty easy id say a 3 out of 10 maybe 45 min per door for a novice mechanic ohh you may wanna replace the strikers too as they wear with a sagging door |
(Post 578893)
you can find them right here
