LT1/LT4 Tech 1993-1997
electric water pump
Old Jun 11, 2006 | 04:36 AM
Saint_Ali's Avatar
Default electric water pump
has anyone used a electric water pump or have any experience with them ? i have heard that they dont leak but there life expectancy is low. does it completely replace the mechanical water pump ?
Old Jun 11, 2006 | 12:27 PM
SickSickSick's Avatar
Default RE: electric water pump
and then some ... you'll have to do alot of bracket mods to run your alternator and power steering without the stock water pump. unless your doing it for race purposes ... better stick with the stock water pump. Sick
Old Jun 13, 2006 | 02:01 AM
What year & engine?
Old Jun 13, 2006 | 05:41 PM
Saint_Ali's Avatar
93 lt1
Old Jun 14, 2006 | 01:04 AM
Your engine is pretty simple.
1 Remove the water pump, it will be reused so don't mangle it.
2 Remove water pump drive shaft from timing chain cover
3 Plug hole in chain cover with plug provided with electric pump motor
4 Remove front cover from existing water pump and attach electric motor in its place, Motor will engage existing impeller
5 Put water pump back & wire it up
6 Make sure to follow instructions included with kit.
Keep the optispark DRY !!!
Keep a spare pump motor handy, they do die a lot. That is why the factory does not use them.
joer6
Mar 2, 2008 07:32 PM
ztothe28
Apr 27, 2007 02:34 PM
hardwire666
Aug 16, 2006 07:26 PM
SickSickSick
May 27, 2006 12:37 PM
