LT1/LT4 Tech 1993-1997
Could it be the clutch???
Old Nov 16, 2007 | 07:49 PM
camarorz28's Avatar
Default Could it be the clutch???
ok guys i'm having somewhat of a problem with my car, ok so this is what its doing. When i punch in the clutch i can hear a sound kinda like chattering like if something is loose and is hitting on something, also when i'm releasing the clutch when on gear from 1st, i can only hear it at 1st gear it sound like is chattering and once the clutch is about 80% fully out it stops, also sometime i have the clutch in and it wount shift into any gear and after a few tries it shifts, any idea??
Old Nov 16, 2007 | 08:00 PM
Default RE: Could it be the clutch???
Release bearing, or pressure plate.
Old Nov 17, 2007 | 02:11 AM
camarorz28's Avatar
ORIGINAL: z28pete
Those are not sold separate are they?? what do you think i should do pete?
Old Nov 17, 2007 | 12:44 PM
Yes, they are sold separately. Either one requires that the transmission be removed, so don't buy parts till you have taken a good look. However, due to all the labor involved,this would be a good opportunity to replace the clutch disk, pressure plate and release bearing at the same time, and don't have to worry about the clutch for a long time.
Old Nov 18, 2007 | 12:05 PM
camarorz28's Avatar
yes that is what i'm thinking to just replace the clutch unit, also what would i need to replace my rear main seal, since my tranny will be remove, i might as well replace it
dogdog130
Jun 28, 2012 04:28 PM
locotrician
May 16, 2009 11:18 PM
bluegreenta
Dec 21, 2008 09:24 PM
Rise65
Nov 8, 2007 10:58 PM
Pro_built7
Apr 10, 2007 02:07 AM
