LT1/LT4 Tech 1993-1997
coolant temp gage inop
Old May 3, 2012 | 10:12 AM
mloaks's Avatar
Default coolant temp gage inop
The coolant gage in my 95 Z28 LT1 does not move.
This began a few days ago, and after I had the alt out.
I am broke and own no test eqpt. Any help is appreciated!
Ideas? When I replaced the water pump last year, I used the existing temp sensor...
Old May 3, 2012 | 10:31 AM
The LT!1 used two temp sensors, one for the gage on the driver side head, and one for the PCM on the water pump. The one you are interested in is the one on the head, at it only has one wire, Unplug the wire from the sensor and connect it to a good ground. Turn the engine on, if the wire and gage are good, the gage will show full hot. This indicates the gage and wiring are good and that the sensor is probably bad. If the gage does not move, it is a good indication that the problem is with either the gage or the wiring, and that the sensor is most likely good.
Old May 3, 2012 | 10:46 AM
mloaks's Avatar
Smile
Thanks, Pete!
So, the gage sensor does not input to the PCM? The car runs fine, btw...
Will follow yr advice asap!
Old May 3, 2012 | 11:45 AM
drive334's Avatar
thanks so much i was having the same problem with my 94 z28 and didnt know where to look.
grasshopper645
Jan 27, 2013 03:08 PM
williambubeck777
Jan 26, 2010 07:09 AM
bidicamaro
May 23, 2008 12:04 AM
EddieTheRipper
Sep 24, 2007 12:00 PM
camarooner
May 14, 2006 02:38 AM
