LT1/LT4 Tech 1993-1997
Computer troubles
Old Jan 11, 2008 | 11:31 AM
FoxRacing74's Avatar
Default Computer troubles
I have a 94' Z28, and I need a little help with a problem. I had my power programmer hooked up to it and the battery on the programer went dead. So i had to change the battery in it and now it wont work with my computer and my car wont start. So i called up hypertech and they said that the only way to fix is to get the computer flashed by a dealership or buy a new computer, and I have to buy a new programmer. Does anyone know any alternatives? or is this the only thing I can do?
Old Jan 11, 2008 | 01:11 PM
02StanGT's Avatar
Default RE: Computer troubles
That's weird. The only programmer I've owned, didn't use batteries... Just the power from the car. They are correct. You're pretty much screwed about that. I'm glad I have my HPTuners.
Old Jan 11, 2008 | 03:19 PM
LT1RUNNER's Avatar
That sucks!! Was this a new programmer? If so shouldn't Hypertech have a warranty for something like this? Or at least be willing to lead you in the right direction.
Old Jan 11, 2008 | 05:50 PM
Hypertech warns about the battery on the programmer going dead and the computer getting all messed up. Call your local Chevy dealer, or some shop with a Tech 2 scanner, and get the PCM reflashed. Then forget about that hand held stuff and get yourself a tuning program that runs off a laptop.
Old Jan 11, 2008 | 06:02 PM
libertyforall1776's Avatar
Hey Pete, could you recommend any? I have a Mac, so do you know of any that run on Mac OS X on Intel (like MacBook Pro)?
Thanks!
Closest thing for Macs I found is QCar:
EDC-1
EDC ("Engine Data Collector") is a special adapter, developed by Q-Branch. This small device connects to the car engine's sensors (rpm sensor, fuel injector, speed sensor, battery voltage). This allows more exact measurements than by using the standard OBD output. EDC-1 can also be used on older vehicles, that do not have OBD connector. The connection to the car sensors is high-impedance and does not interfere with vehicle's operation at all.
http://www.qcar.nl/hardware.html
and Consultans, but for Nissans:
http://members.***.net/~epooch/consultan/
Old Jan 14, 2008 | 05:30 AM
Thanks guys for the input. Thats pretty much what I thought I was going to have to do.
Christophern
Nov 29, 2010 11:04 PM
blaclabel250
Aug 21, 2007 01:44 PM
sweet1967camaro
May 11, 2007 01:14 PM
