93 rpm troubles
Old Aug 5, 2007 | 10:13 AM
blaclabel250's Avatar
Default 93 rpm troubles
I have a 93 camaro with the 3.4 motor and recently my car decided to quit going over 4200 rpm. heres what was all done in an attempt to fix this problem...new plugs/wires, o2 censor, ignition module, tested coils(ok),fuel filter, tested fuel pressure(ok), unplugged knock sensor(didnt help), replaced map sensor, new air filter, pulled cat to see if clogged, none of this made any difference and im getting a bit annoyed having to replace all this crap that doesnt need it if any one has any ideas please let me know thankyou
Old Aug 5, 2007 | 10:42 AM
Default RE: 93 rpm troubles
Does the car start misfiring, or it just won't rev any higher?
Old Aug 5, 2007 | 10:57 AM
it seems to like bog out wont no misfire or backfire nothing like that laast night i disconnected the battery in hops of resetting the computer but that did nothing
Old Aug 5, 2007 | 11:00 AM
and i probably should have mentioned that it wont upshift when i punch it cuz the rpm diesnt go high enough which is how i found out about the problem when driving casually there is no problem shifting at all. a buddy of mine goes to wyotech and he thinks its the tranny but id doesnt make sense to because it not getting to the high rpm it needs to shift
Old Aug 5, 2007 | 01:56 PM
You may want to check out the cat converter. They can partially clog up and as the engine tries to speed up the backpressure holds it back and won't let it rev any higher.
Old Aug 20, 2007 | 10:18 PM
i did that was actually one of the things i mentioned initially
Old Aug 21, 2007 | 12:12 PM
viciouZ's Avatar
Is your CEL on?
Old Aug 21, 2007 | 01:44 PM
im assuming thats the check engine light. no its not
glue maker
May 3, 2010 11:04 PM
DacMan
82-92 V8 Tech
Aug 11, 2009 07:27 AM
KS77
Aug 7, 2009 05:11 PM
madmike91
Jun 14, 2007 03:42 PM
