Confused
Old Aug 19, 2007 | 07:12 PM
hvacben's Avatar
Default Confused
I just tried to do an oil change on my 2000 SS and I couldn't find the oil drain plug. I found the oil filter and two what looked to be plugs behind a metal shield with 4 drilled holes where the bolts were. Am I looking in the right place if so does that metal shield come off.
Old Aug 19, 2007 | 07:46 PM
o2camaross's Avatar
Default RE: Confused
the drain plug is in the bottom of the oil pan, you can't miss it, look again.
Old Aug 20, 2007 | 08:15 AM
hvacben's Avatar
Yeah but there is some type of metal shield in front of it and it looks like the drain plug is recessed about 4in behind it. I know,I feel really stupid for asking this kind of question but I can't seem to find it. I'll see if I can take a picture of it maybe that might help.
Old Aug 20, 2007 | 09:21 AM
JD1969's Avatar
It's not behind any shield and it's not recessed at all. It's on the side of the oil pan near the middle.
Old Aug 20, 2007 | 07:18 PM
hvacben's Avatar
Ok so laying underneath the car you see the oil filter on the left of drain pan so in reference to that where would it be? I know this sounds really bad but this is my first V8 I've been into jap cars for the last 6 years this is definetely a first for me not finding the drain plug. The weird thing is I found the plug and I swear its behind a shield. Apparently after talking to a couple of guys at work, they said they had similar issues where there was a shield that needed to be removed it was used to block debris from smacking against the drain pan. I was under the car yesterday for a half an hour and all I could find was a plug behind this shield. I'm gonna try it again and if I still can't find it I'll take a picture of what I'm talking about.
Old Aug 20, 2007 | 09:12 PM
Oil plug pix.
Old Aug 20, 2007 | 09:30 PM
Chappie99's Avatar
The plug behind the metal shield is your transfer case..Oh, wait you have a Camaro..Just use a screw driver and a hammer and punch a hole in the pan to get the oil out..Or just put your hand on the oil pan and start at the top and slide your hand down till you feel a bump, that bump is either a dead squirrel or your drain plug. Oh about the screw driver and hammer thing, if you do that, you should be shot..
ORIGINAL: hvacben
Old Aug 20, 2007 | 09:59 PM
hvacben's Avatar
Thanx Pete I do appreciate it. Now how do you drive a camaro...just kidding
Old Aug 20, 2007 | 10:19 PM
hvacben's Avatar
Where did you get that photo? Do you have the dealers manual by any chance? I got the one for my old Eclipse online for free but I can't find one for the SS.
Old Aug 21, 2007 | 01:52 PM
www.alldatadiy.com$25 per year.
drummabrotha
Nov 22, 2011 07:26 PM
stainless1911
May 14, 2011 12:46 AM
McMarcus
Jul 13, 2010 12:39 AM
r6rider
Nov 13, 2009 07:13 PM
bd92rs
Mar 10, 2009 10:22 PM
