LT1/LT4 Tech 1993-1997
Chech engine light
Old 02-19-2008 | 12:29 AM
95z281LE's Avatar
Default Chech engine light
I have a 95 z28 i just recently added AFR heads a custom grind cam550/550 lift 112 lsa. Today I was going to go dyno the car. When i started it everything seemed normally. I was standing outside of the car smoking (I do not smoke in the car) letting it warm up and I heard the fans turn on so I got in the car and the check engine light was on. I know that I need to get the car scanned and my buddy is coming over tomorrow to do it I was just wondering if anyone has heard of something like this before?
Old 02-19-2008 | 12:36 AM
MassholeLT1's Avatar
Default RE: Chech engine light
My car does the same thing- fans come on, check engine light comes on. The fans also seem to come on at times when the car isnt fully warmed up....however the car only does this periodically. Im getting my car scanned soon....let me know what your codes come up as- probably the same issue. I have heard this could be the A\C Temp. Sensor, which causes the car to think the air is on, which causes the fans to activate when they shouldnt. Let us know what you find out....
Old 02-20-2008 | 02:21 AM
95slvrZ28's Avatar
My car does the same thing as well haha, let us know! I think it could be a lot of things though because if a sensor is giving bad data the computer can start ignoring it and going into open-loop mode, so the fans turn on. Nonetheless, let us know what you find out! My bets are on an O2 sensor!
Old 02-20-2008 | 02:38 AM
Interesting...Well I guess we both will hopefully both learn something here 95slvrz28!
Old 02-20-2008 | 01:56 PM
When certain trouble codes are set, the PCM turns on the fans to protect the engine. They are supposed to act that way. When the check engine lite goes on, the PCM has to be scanned to see what the complaint is. It is cheaper to scan than to throw parts at the engine for no good reason.
Old 02-21-2008 | 01:34 PM
Any news on what the problem turned out to be?
Rent
04-23-2013 12:08 AM
husker_camaro95
11-22-2010 07:19 PM
Chevykicksbut
10-28-2009 08:14 AM
SCSUCamaroJunkie
09-13-2007 10:49 AM
rambo619
02-15-2007 10:12 PM
Quick Reply: Chech engine light
