Intermittent Chech Engine
Old Sep 12, 2007 | 12:34 PM
SCSUCamaroJunkie's Avatar
Default Intermittent Chech Engine
I have 94 Auto Z28 and my check engine light comes on only when im moving or when I am in neutral. If I stop at a stop light or sign the light will go off. The car runs fine and there is nothing else wrong except the fans come on when the light come on but that is probably because of the light since the car is not running hot. I would get it scanned for free at autozone or a place like that, but they only have the scanners for 96 and newer vehicles and I don't want to pay a dealer one hundred dollars for a scan. Has anybody herd of a problem like this because it is very annoying and im guessing it is a sensor somewhere. MAF or MAP? Someone help?
[IMG]local://upfiles/9806/64D548F205934AA6A2DEDD6E9E4671B1.jpg[/IMG]
Old Sep 12, 2007 | 05:30 PM
brucehusker's Avatar
Default RE: Intermittent Chech Engine
I'm pretty sure you can get a code reader for your engine, if it's OBD I, for around $35. Check on E-bay. There's a GM specific one. I'm one of the lucky 95 owners with an OBD I system but an OBD II connecter, so I can't use the cheap one. I would get one if I were you. It could be a lot of things and it's just too hard to guess correctly if it shows no symptoms. Hope this helps.
Regards...Bruce
Old Sep 13, 2007 | 09:49 AM
Turbozombie's Avatar
My 94 Z28 has an OBDII connector but OBDI computer. The cheap scanner does not work for me either.
Fuerst94
Nov 8, 2011 07:35 AM
bradspaugh
70-81 V8 Tech
Jun 8, 2011 08:07 PM
HorizoN
82-92 V8 Tech
May 19, 2010 10:38 AM
fredizdman
82-92 V6 Tech
Oct 23, 2009 11:44 AM
95z281LE
Feb 21, 2008 12:34 PM
