LT1/LT4 Tech 1993-1997
brake lights and turn signals
Old Nov 15, 2006 | 10:54 PM
chrisb6560's Avatar
Default brake lights and turn signals
Alright, my fin brakelight is the only one that works. I've changed all my bulbs and checked fuses and can't find the problem. It actually worked one time for about a day. I'm thinking a wiring problem.
And my turn signals stay on, inside and out. I changed my hazard flasher because my Haynes mentioned it could be the problem but it didn't work. Fuses are good, any ideas?
Old Nov 16, 2006 | 12:48 PM
uncle bill's Avatar
Default RE: brake lights and turn signals
I had the same problem on a '96 Tahoe and it turned out to be the turn signal / cruise control switch. Go figure!
Old Nov 16, 2006 | 07:09 PM
camarorz28's Avatar
my brother had the same problem in his firebird about the light signal staying on and not flashing, it turn out to be the wire harness were the bulb goes try that out. see if u can get one at a pick n pull and check it out.
67Harbor
Oct 7, 2013 06:38 PM
ayagle
Jul 21, 2010 12:54 PM
nitrojunkie
LS Series Tech
Mar 1, 2010 08:04 AM
Blasko
Jun 15, 2009 07:46 AM
BAV
Mar 9, 2009 02:18 PM
