LT1/LT4 Tech 1993-1997
could it be my thermostat?
Old Nov 13, 2006 | 11:08 PM
camarorz28's Avatar
Default could it be my thermostat?
Hi my 94'z overheated yesterday the neddle almost got to the red. I could not hear the fan turn on, so i turn it on manualy. When i got the car it came with a switch to turn on the fan manually. So i turn it manually and the temperature started dropping. The car does not take long to heat up. it is always running just a lil below half line. One question is it bad if i always have my radiator on?? if i turn on the switch all the time even when i just started the car from beign cold? thanks
Old Nov 14, 2006 | 12:59 AM
shnormo's Avatar
Default RE: could it be my thermostat?
It could be your thermister resistor. It is a variable resistance potentionmeter that changes resistance withe heat. Sounds like that went bad. It is not bad to run your fans all the time, but I still like the motor to get up to operating temps before turning them on. It's also good to leave em run a little after you shut it off.
Old Nov 14, 2006 | 08:26 PM
Your fans, unless they have been molested, are turned on & off by the PCM depeding on the input from the coolant temperature sensor. There are several relays involved, under PCM control, depending if your 94 is an early or late production model. In early production the fans were turnrd on & off one at a time depending on the temperature. On later production both fans were turned on & off at the same time, but the speed was changed depending on need. If the sensor is bad it will also affect the way the car runs, as the PCM alaso uses the same input to determine the A/F ratio.
Old Nov 16, 2006 | 02:52 AM
camarorz28's Avatar
ORIGINAL: z28pete
So what should i do? Oh i wanted to input some more info. i just remember. When i got the car a guy game me a Power Programmer and the fan was working good. But i think that since the other day that i plug in the programmer and return the car to stock. I read that u can put another thermostat a diff. temperature thermostat , could there be a different thermostat in the car that the guy install and change with the programmer, could this have affected the fans to not turn. Oh and i'll check up if the car is late model or early model
Old Nov 17, 2006 | 01:02 PM
First of all try a new cooloant temp sensor & see if the fans work any better, or you can leave the fans on manually. A lower temp thermostat would only make a difference at highway speed, as the fans need to be set up to turn on sooner to match the thermostat. Personally, I would like to find out why the manual switch was put on, and how it was put on, since when wiring gets molested starnge problems can be started.
Old Nov 17, 2006 | 08:03 PM
camarorz28's Avatar
it seems like they got a wired ready to manually turn on the fans. I saw one on the internet, i've changed the e-brake the other day cuz it was broken and i saw the wires for the manual fan turn on. I think its like an adapter i dont know if anyone knows about it i'll try to see if i can find out, and i'll try a new coolant temp sensor, were is the sensor at?? check it out this is the manual switch.
http://store.summitracing.com/partde...5&autoview=sku
SalsCamaro2000
Dec 14, 2011 12:38 PM
MaxTheKiing
Jun 22, 2010 11:30 AM
bluovlh8er
May 17, 2007 02:05 AM
RJayS.
82-92 V8 Tech
May 16, 2007 10:25 AM
bowtie.runner
May 7, 2007 11:32 PM
