LT1/LT4 Tech 1993-1997
Body Control Module replacement
Old Nov 6, 2010 | 05:23 AM
bgribben's Avatar
Default Body Control Module replacement
I have a 1996 z28 and am having issues with no power when I open the door in weather under about 45 degrees but can start the car by applying heat to the glove box area. I feel I am having issues with my body control module but as I went in to see if this is something I could replace on my own I noticed BIG warning about setting off the passenger side airbag.
Any advice on this? Should I proceed or just take it to a dealer?
Thank You
BGribben
Old Nov 9, 2010 | 10:42 AM
mab6680's Avatar
if you disconnect the battery for like 10 min do discharge the back up battery for the air bags they wont go off
Old Nov 9, 2010 | 11:04 AM
Massey's Avatar
You can remove the BCM without touching the air bags. It is located behind the glove box on the passenger's side and it appears you have the relay issue. Check the BCM rapair thread on the main 4th gen page sticky list. It tells you how to fix what is messed up.
Massey
Massey
Jan 15, 2025 04:36 PM
Camero Cowboy
Aug 9, 2013 09:36 PM
Bill in Ft Lauderdale
May 20, 2011 09:46 PM
1999chevy
Nov 17, 2009 05:32 AM
98sleeper
Apr 20, 2008 06:39 PM
