Body control module
Old May 4, 2009 | 04:12 PM
1999chevy's Avatar
Default Body control module
hey does anyone know how to check to see if a bcm is working or not???
Old May 4, 2009 | 06:13 PM
evilkal's Avatar
Do your lights come on? If so, your BCM is fine... I replied in your other thread, and it's not your BCM but your RAP module that is going bad. Replace it and all will be well.
Old May 4, 2009 | 07:25 PM
1999chevy's Avatar
ok thx but ant a rap works when u take the key out the it stays on for 10 mins and if its the rap i cant find on any where for a 99 camaro ive tryed ebay and searched places anywhere to look?
Old Nov 10, 2009 | 12:03 PM
nnewquist's Avatar
In '96+ models, the RAP is built into the BCM. 1996 was the first year GM put the BCM in the F-Body. Before that, there was a RAP for keeping accessories running after you turn the car off, and everything else was simple relays.
I know it's been a while since this question was asked, but I found it in my search for my own BCM issues... Hope this helps someone.
Old Nov 10, 2009 | 12:31 PM
auto's Avatar
whats a BCM, and whats it do? all news to me
Old Nov 10, 2009 | 01:15 PM
Most newer cars (OBDII) use a BCM. The BCM controls most of the electrical circuits in these cars. This was done to save wiring and to allow diagnosis of most electrical problems using a scan tool. Unlike most general purpose scan tools that only handle standard power train trouble codes (P codes) this scan tool can read manufacturer proprietary codes which car makers try to hide from the public.
Old Nov 10, 2009 | 04:46 PM
auto's Avatar
wow, but how can you or me be able to scan and read a bcm if its only for manufacturers?
Old Nov 10, 2009 | 10:00 PM
You need a professional type scanner such as SPX/OTC, factory scanners such as the GM Tech III, SnapOn/Solus, etc. These tools can cost as much as good used car. SEMA is lobbying Congress to get regulations passed to make the manufacturers publish all information and make it available to the general public.
Old Nov 17, 2009 | 05:32 AM
srode's Avatar
A tech 2 is about $2000 with an updated card through current year.
Massey
Jan 15, 2025 04:36 PM
Massey
Dec 24, 2015 10:48 AM
Camero Cowboy
Aug 9, 2013 09:36 PM
Bill in Ft Lauderdale
May 20, 2011 09:46 PM
98sleeper
Apr 20, 2008 06:39 PM
