LT1/LT4 Tech 1993-1997
Belt problem
Old Mar 8, 2007 | 01:25 AM
z28ster's Avatar
Default Belt problem
For the past 2 or 3 months my belt keeps slipping off the pulleys. It only happens when i turn hard or do doughnuts. I've changed the belt several times, and i dunno what to do, it annoy's me that i can't do doughnuts, i mean i can but the belt will slip right off which leads to loss of battery life and power steering. Any advice?
Old Mar 8, 2007 | 02:15 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Default RE: Belt problem
I dont know for sure, and this may seem like a silly sugestion to some, but is there a way it could be on backwards? I am only suggesting this because I have worked on nissans (yeah, I know boooo) that had the same problem and I turned the belt backwards and it didnt slip off anymore. Also is there a pully that is not tight enough?
Old Mar 8, 2007 | 12:45 PM
Time for a new belt tensioner? Also make sure all pulleys are lined up and all bolts tight. Try doing doughnuts in reverse &see if the belt stays on. lol
Old Mar 8, 2007 | 05:33 PM
sellc's Avatar
Yes check the belt tensioner but if it seems oksometimes I find that one of the power steering bolts has sheered. It was a problem and they even changed the design on later models and police models.
Old Mar 8, 2007 | 06:53 PM
Saint_Ali's Avatar
maybe you should stay away from donuts, i dont know why they are even called donuts, besides that the tires are round and so are the donuts
Old Mar 8, 2007 | 07:40 PM
camarorz28's Avatar
no, no, no dont stay away from donuts its cool and fun well sometimes, i do them when i get mad, it relieve my anger lol
Old Mar 8, 2007 | 07:54 PM
Personally. I raher eat donuts than make them.
Old Mar 9, 2007 | 02:26 AM
95slvrZ28's Avatar
ORIGINAL: z28pete
I don't know, don't you think if the belt falls off while doing doughnuts, if he does doughnuts in reverse then the belt will probably become too tight and break off some of the pullies, and that'd get damn expensive!
Old Mar 9, 2007 | 03:29 PM
Yeah. I doubt doing doghnuts is the cause, but he may be winding the engine much higher than normal while fooling around, and cause belt problems to show up.
bd92rs
Jun 11, 2011 07:26 AM
ballison
Apr 22, 2009 03:13 AM
Spartan66
Apr 5, 2008 09:01 PM
redchair2000
Mar 26, 2008 12:55 PM
Redeemed
Sep 17, 2007 09:51 PM
