LT1/LT4 Tech 1993-1997
bad gas mileage after replacing almost everything
Old Apr 4, 2010 | 12:25 PM
murderd96z28's Avatar
Default bad gas mileage after replacing almost everything
ok as you guys know from my post i have replaced the opti and all plugs and wires and gapped the plugs to the right specs, im only getting 14 or 15 in town, this normal? last summer i was gettin 16 or 17, im not driving the wheels off it its my daily driver im doin the same drivin now that i did last summer when i was gettin better mileage the only thing i have not replaced is the coil, any ideas anyone
Old Apr 4, 2010 | 01:08 PM
Lazy O2 sesnsors come to mind. Get a scanner and look at the O2 sensors, the voltage should be cycling up & down at quick pace. Also check air cleaner and exhaust system, dragging brakes, low tire pressure, heavy shoes.
Old Apr 7, 2010 | 09:44 AM
Z28pete you the man plugged my comp into the.car. bank1 sensor 1 is new and the voltage bounced all over the place. Bank 1 sensor 2 passenger side is stuck around .8xx. Thanks man good tip!
Old Apr 25, 2010 | 12:29 PM
ryguy425425's Avatar
I don't think your far off of what you should be getting http://www.fueleconomy.gov/feg/bymod...t_Camaro.shtml (about 15 according to this.)
Old Apr 25, 2010 | 05:59 PM
worst i have gotten is 21mpg and the car runs rich. first 93 z28 got 27+mpg. if u havent found the problem test the evap murderd
Old Apr 25, 2010 | 06:41 PM
Yeah, but murderd was talking about around town driving. A car will generally get worse gas mileage in the winter, if you live in a cold weather climate. One reason is because of letting the engine idle more to warm up. Another is some areas have a "winter blend" gas that has more ethanol, which also gives you worse gas mileage.
Old Apr 25, 2010 | 07:52 PM
Grandpaswagon's Avatar
The ethanol that is being put into the gas, both summer and winter blends, is gonna cause a decrease in mileage. I've seen some reports that 10% ethanol can cause a 10% drop in mileage.
Old Apr 25, 2010 | 09:55 PM
so u think tokeland is a small place out in the middle of nowhere? lol. summer whats that?
http://marcymerrill.smugmug.com/Land...43208754_8GCzz
Old Apr 25, 2010 | 11:25 PM
You mean Tokeland is a real place? I thought that was an altered state of mind you sometimes get yourself in...
Robert Macpherson
Mar 10, 2012 02:31 PM
spectre460
Mar 23, 2008 11:47 PM
The Corvette Doctor
Nov 15, 2007 10:42 PM
davidfarah
LS Series Tech
May 11, 2007 01:51 PM
JaySan
Apr 17, 2007 09:38 PM
