Bad Gas Mileage NEED SOME HELP
Old Apr 15, 2007 | 06:49 PM
JaySan's Avatar
Default Bad Gas Mileage NEED SOME HELP
My car is getting bad gas mileage what should I do?I have already replaced theair filter, fuel filter, and got this stuff from autozone that cleans the fuel injectors but i have to put it in with a full tank of gas. Thanx in advance.
Old Apr 15, 2007 | 06:54 PM
74454bb's Avatar
May 2007 ROTM
Default RE: Bad Gas Mileage NEED SOME HELP
New spark plugs. Maybe wires.
Old Apr 15, 2007 | 07:22 PM
badinfluenceRS's Avatar
O2 sensor, tires inflated properly, brakes rubbing...
Old Apr 16, 2007 | 12:02 AM
blink18236dude's Avatar
do a seafoam maybe. heres a link i found to show how to do it.
http://www2.ls1tech.com/forums/showthread.php?t=534376
Old Apr 16, 2007 | 12:59 AM
JaySan's Avatar
so if my rotors are sqeaking that could give me bad gas mileage?
Old Apr 16, 2007 | 01:28 AM
bluovlh8er's Avatar
no, you have to do your front breaks lol.
Old Apr 16, 2007 | 01:46 AM
JaySan's Avatar
is it hard to replace the O2 sensors? How can you tell if they are bad ? If i replace the spark plugs which brand would give me better performance ?
Old Apr 16, 2007 | 11:58 AM
well...if the brakes are rubbing, then the car doesn't accelerate and cruise as easily, therefore you have to give it more gas...so it can affect the mpg a little...
NGK and ACDelco spark plugs are good...
O2 sensor is easy...I'd stay away from autozone cheapo brands, I'd get AC Delco parts
Old Apr 16, 2007 | 01:57 PM
74454bb's Avatar
May 2007 ROTM
Bosch platnium + 4's are great plugs, you'll see a difference.
Old Apr 16, 2007 | 10:39 PM
ORIGINAL: JaySan
If the MIL lite is lit you need to take of that problem first. Otherwise go for a new set of plugs and wires. Misfires, dirty air filters,and bad O2 sensors are the main cause of poor mileage in computer controlled cars.
The O2 sensor has a great bearing on fuel economy. They are easy to change out, about the same as changing a spark plug, except thatyou need a sensor socket to avoid twisting the wires off.They can only be tested by using a scan tool and observing the frequency of the voltage change. Slow or nor changes=lazy sensor=poor fuel mileage. I recommend you stay away from Bosch sensors. Get Delco or Denso.
