LT1/LT4 Tech 1993-1997
auto to a stick
Old Jan 1, 2011 | 10:28 PM
sgtdupree's Avatar
Default auto to a stick
My maro is an auto. I was told that it's easy to change to a stick because maros come with some type of universal set up. does this sound true. how hard or should I say expensive would it b to make the change cuz I would have a shop do the work
Old Jan 1, 2011 | 11:17 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
My car has the t56 swap. the best thing to do is find a donor car and get all the parts you need in one shot. i also went with the Tick Performance custom master cylinder which is an upgrade from the weak stock piece. Depending on the transmission your swap can cost anywhere from 1500-5000.
Old Jan 2, 2011 | 11:39 AM
osduck5's Avatar
^^^^^ what nj85 said! I thought the wiring harness was also different but not sure.
Old Jan 2, 2011 | 01:57 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
You can buy the T56 plugs you need off of ebay for about $30 and rewire what you have.
I also went with the LS7 Clutch/LS2 Flywheel and the Tick Performance Stage 2 T56 and the GMPP slave which made my swap a little more money than most.
ssduane
Jan 8, 2008 01:02 AM
Vtec Sucks
Jan 5, 2008 03:32 PM
zerokool91
Sep 13, 2007 08:18 PM
simio312
Apr 15, 2007 09:59 PM
gozzy341
Apr 14, 2007 09:33 PM
