LT1/LT4 Tech 1993-1997
Are RR's the same from Older Carb'd Motors as the LT1
Old Dec 31, 2010 | 01:01 PM
wicked94z28's Avatar
Default Are RR's the same from Older Carb'd Motors as the LT1
Hey guys I already have them installed but figured I'd make sure... I have a 350 Carb'd motor build in my old 3rd gen that I ended up parting out and started my 4th Gen LT1 Build... So the RR's are like brand new and im pretty sure I could use them but wanted to see if someone else done it before... So there Crane Gold 1.6.. there not the skinny ones there kind of wider.. Just wanting to make sure 100% on stuff after reading the build that went wrong with the other guy LoL...
As for my Build its a LT1 Block from a 93 maro.. Bored, Strocked, 383 Eagle Rotating Assembly with srp ion pistons, Comp Cams XFI292 cam.. Stock heads done to 2.02, 93 intake ported to match heads and my 58mm BBK TB, 38lb injectors, 10.2 wires, NGK Iridium Plugs, Polished LongTubes, I also have a EFI Zex kit that im gonna spray a 125 shot(built to take much much more)... I still need a couple thing to finish the motor up and then with income tax im gonna do the suspension... wanting low 11's maybe a high 10 would be nice!!!
Old Dec 31, 2010 | 01:21 PM
If you guys wanna see some pics of the build and also pics of the rr's there on my facebook http://www.facebook.com/photos.php?id=100001163442050.. older pics but i will do some updating as soon as its warm enough to walk to the garage lol
Old Dec 31, 2010 | 01:24 PM
Link does not work. I get Error: This content is currently unavailable.
Old Dec 31, 2010 | 06:51 PM
do you have a part number for the rockers? if you have the wider ones you may have to mod your valve covers or get some oversized ones.
Old Jan 2, 2011 | 11:32 PM
Hey Idk why the link isent working its to my facebook page, but they dont have a part number on them... and I got the canton covers so I know they'll pass with ease, just wanted to make sure there wasent a difference from the older motors to the newer ones... and when i try to post pics it says there to big.. is there a way to make them smaller? also i just picked up a set of c5 stagerd wheels yesterday and got a ? about tires im going to post in a day or so... if you guys could help me with the pic uploading thing then you'll actually be able to see the rockers and that'll probly help you out alot!!
madenmiami305
Aug 18, 2009 10:52 AM
thirdgencammyman000
82-92 V8 Tech
Apr 17, 2008 06:57 PM
Est.1987
Jun 11, 2007 05:22 PM
