What all would i need to go from Auto to Stick ?
Old Sep 11, 2007 | 03:15 PM
zerokool91's Avatar
Default What all would i need to go from Auto to Stick ?
1st, What speeds are there ? 4 - 6 ? for a 1991 camaro RS. My 700R4 is about to take a crap. And it is simply because of the fact of I like dropping my gears down to slow the car down too often.. It is starting to make a pinging sound almost like a quick tick tick tick tick tick tick ..etc ... but what all would I need to convert from and automatic to a manual tranny ? And what would be the ball park price range ?
thanks much,
Z3R0
Old Sep 11, 2007 | 04:10 PM
RSZ28SS's Avatar
Default RE: What all would i need to go from Auto to Stick ?
depending on the year all 3gen's came with a 4 or 5 speed manual or a 3or 4 speed automatics
you are going to have to call the gunk yard unless your think about getting it allnew ???
i think you should just stick with what you have a 700r4 is a good transmission but if i where you i would get it rebulit and put in a shift kit that will take care of your problem
and i dont understand why your droping the gears just use your brake
that sound might be your universal joint smell your transmission fuild if it smells burnt then i would suspect your transmission
Old Sep 12, 2007 | 08:26 AM
TRIPSxZ28's Avatar
I know this doesn't answer your questions, but I have an auto 700R4 tranny with a shift kit and I enjoy it.
I only have a 305 but I can bark them tires through second. I would rather have a stick, but it seems to expansive and to much work to swap it out. The cost I dunno, but would like to know myself.
Old Sep 12, 2007 | 08:48 AM
Jr. Mechanic's Avatar
August 2009 ROTM
The reason your transmission is dying is because of the fact you like to shift it manually, as said in your other post. That is not good for the gears, AT ALL! Neutral drops are extremely bad too. Downshifting manually is not problem. If you want to go manual, I have a 5spd transmission with pedals and everything. Do you have a v6 or a 305? If you want to go auto, just get your 700r4 rebuilt or put a turbo 400 in.
Old Sep 12, 2007 | 10:03 AM
Saint_Ali's Avatar
its a waste of time and money to convert it to manual, if you want a stick buy a car with a stick
Old Sep 12, 2007 | 12:04 PM
1985RS's Avatar
hey man, if he wants to convert his car to stick you shouldnt put it down. converting to a stock camaro 5 spd drivetrain is a lot cheaper than buying another camaro thats 5 speed, especially with how good of condition his car is in right now. if your set on stick, you will need the brake and clutch pedal assembly from amanual camaro/firebird, clutch fluid resevoir, slave cylinder, clutch, flywheel, bellhousing, trans, driveshaft, shifter, and possibly the console or at least the shift plate from a manual. its a lot of work, theres a bunch of how to articles on the net about doing it. but if you have the desire and the patience it can be done.
Old Sep 12, 2007 | 02:21 PM
TRIPSxZ28's Avatar
That definatley sounds like way to much work and money. I think I'll stick with my auto
and just rebuild the tranny, and maybe get a new shift kit.
Old Sep 12, 2007 | 10:54 PM
zerokool91's Avatar
ORIGINAL: Jr. Mechanic
Are you willing to get rid of all of that ? If so, how much and will it fit in my 1991 RS w/ 305?
Old Sep 13, 2007 | 08:18 PM
August 2009 ROTM
Pm sent
sgtdupree
Jan 2, 2011 01:57 PM
ssduane
Jan 8, 2008 01:02 AM
Vtec Sucks
Jan 5, 2008 03:32 PM
simio312
Apr 15, 2007 09:59 PM
gozzy341
Apr 14, 2007 09:33 PM
