another problem: fuel pressure leak
You won't blow up leaving the cap loose driving to work. But just curious you say you smell gas and it gets crappy mpg. Along with a loss in power. Have you bothered to possibly check the fuel pressure?
The regulator could be bad if it is the original. That wouldn't explain your hissing. Cept that I believe there is a burp valve or some sorts back at the tank that vents the tank when the car isn't running. So it may have been normal.
