LT1/LT4 Tech 1993-1997
another problem: fuel pressure leak
Old May 8, 2010 | 06:46 AM
2fast4u88's Avatar
You won't blow up leaving the cap loose driving to work. But just curious you say you smell gas and it gets crappy mpg. Along with a loss in power. Have you bothered to possibly check the fuel pressure?
The regulator could be bad if it is the original. That wouldn't explain your hissing. Cept that I believe there is a burp valve or some sorts back at the tank that vents the tank when the car isn't running. So it may have been normal.
Old May 9, 2010 | 03:38 PM
White94Z28's Avatar
i had the pressure tested a while back and it was great, but that might have been before the problem started. it only happens when i drive the car around then stop i will notice the hissing sound coming from the rear of the car then i open the gas cap to bleed the pressure and it stops
Jparker7269
Oct 24, 2014 07:10 PM
fire43f
May 10, 2012 10:47 PM
fperezii
Feb 5, 2012 12:52 PM
BigCat2010
Apr 21, 2010 12:33 AM
