LT1/LT4 Tech 1993-1997
what next after bolt on's
Old May 8, 2010 | 06:49 PM
BMCossey97Z28's Avatar
Default what next after bolt on's
so i got all my bolt on's, i got the air coming in and going out real good. what would be the best route for more power? also is there an easy way to do the plugs and wires on the passenger side of motor?
Old May 8, 2010 | 08:45 PM
gotta let us know what u have in the car now. have u checked out the sticky? besides sumit and jegs check these places.
http://performabuilt.com/gm%20perfor...d=16&Itemid=38
http://marylandspeed.com/index.php
http://www.spohn.net/
http://www.elliottsportworks.com/lt1.html
http://www.stranoparts.com/
Old May 8, 2010 | 09:34 PM
im brand new to this site so im still figuring out how to work my way around it, what are the stickies?
Old May 8, 2010 | 09:35 PM
torque_is_good's Avatar
since you have all the bolt ons, then we can assume that you have long tube headers so the passenger side is really not that bad.
from below, do plug #8 by putting the plug socket onto the plug and use a box wrench to turn it.
# 6 can be done from above or below but 2 + 4 from above.
here's a hint, sometimes it's easier to lay on top of the motor (across it) and you'd be surpised how it improves the angle.
With long tubes, it takes longer to jack it up, chalk the wheels, get out the tools and then put everything away than it does to replace the plugs.
Old May 8, 2010 | 10:08 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
What is your definition of 'all my bolt ons'? is it still natrually aspirated?
Old May 9, 2010 | 12:16 AM
stickies are at the top of the sections. one is at the 4th gen page and reads where to start modding. the lt section has one for cams.
Old May 9, 2010 | 11:06 AM
Turbolag86's Avatar
So the passenger side is the even numbers on the cylinders? I thought the driver side was even.
Old May 9, 2010 | 12:40 PM
well i dont have every bolt on but i got slp headers, duel single chamber flomasters, 2.5 in pipes, k&n cold air, 58 mm TB, msd 6a ignition, msd coil, high performance plugs and wires. i was thinking about getting a chip next. has anyone had any good experiences with a certain chip? also my z just rolled 100k, it still runs really strong but im cerious if i should build up my motor to withstand higher hp, i would hate to give it all this power and then it through a rod or something else.
Old May 9, 2010 | 12:56 PM
unless u have a good sized cam and ported heads the 58mm tb is not doing any good. your gona want to get the heads done and pick up a cam, lifters, and 1.6 rockers. whats been done to the intake? did u look to see what elliotts has to offer. lloyd is very good. stock bottom end is pretty strong so u should be safe to 400hp.
Old May 9, 2010 | 02:05 PM
whammer3024's Avatar
ROTM Winner
have you done anything with your gears? are you stick or auto? if auto you're going to want to get a different torque converter. then i'd look into the heads and cam
