LT1/LT4 Tech 1993-1997
Aftermarket TB IAC Isolation Solution
Old May 15, 2019 | 09:46 PM
NorthernCrew454's Avatar
Default Aftermarket TB IAC Isolation Solution
Hi All,
I have a professional products 58mm throttle body with the dreaded non isolated IAC passage way commonly seem with aftermarket throttle bodies. I am chasing split BLM's at idle and this was one of the solutions to keep air out of the main plenum at idle. I counterbored and press fit in an aluminum tube, the BBK gasket uses a round hole around the IAc hole so it seals the tube perfectly. I have seen this done with copper tubes and epoxy but couldn't get over the idea of epoxy coming loose and going into the engine.
Old May 19, 2019 | 07:45 AM
did it work
Old May 21, 2019 | 08:26 PM
This has worked great, I had to open up the "drill hole" to give more air as air was not bleeding into the plenum anymore.
Old May 24, 2019 | 10:29 AM
kool, added to the lt1 faq sticky
kblood
Nov 5, 2013 10:44 AM
skinut
Dec 27, 2011 01:24 PM
wils5150
Jun 12, 2010 06:58 AM
sidewayz28
Dec 21, 2008 11:44 AM
95camz28
Dec 1, 2007 12:17 PM
