LT1/LT4 Tech 1993-1997
'97 Camaro z28 has trouble starting...
Old Jul 16, 2010 | 08:04 PM
if it starts that points to either the fuel pump or fuel pressure regulator goin.
Old Jul 16, 2010 | 08:08 PM
speeddemon0712's Avatar
Oh so this test is to see if my fuel pump is bad? Cause if it starts right up after a few primes, more gas has got to the engine that the fuel pump didn't get in the first place?
Old Jul 16, 2010 | 08:22 PM
right the pump is on for 2 seconds to prime and if the pump is not working right it doesnt get up enough pressure to start the car. when you try to start it the pump will come on and after a few seconds it will get up the pressure needed. the pressure regulator is the same idea. if its open all the time the same thing happens. if you have a fuel pressure gage you can test to see whats going on. i used a clamp on the return line to find the pressure regulator was failing..gotta be careful on the plastic pipe, it cracks easy.
Old Jul 16, 2010 | 08:27 PM
Awesome... I'll look it over with my moms fiancé, he's pretty mechanically inclined. Thanks for your help.
sgtdupree
Jan 17, 2011 11:05 PM
thegad
Jan 17, 2011 04:50 PM
neva_aquainted
Aug 26, 2008 09:51 PM
SilverBullet5
Aug 1, 2008 04:24 PM
94lt1camaro
Jun 25, 2007 08:38 PM
