LT1/LT4 Tech 1993-1997
93 Z28 no start. has spark, fuel & air. What else is there?
Old Sep 8, 2010 | 11:16 PM
Bessette's Avatar
They didn't look that bad when I checked the comp. A little dark but not wet. they have about 5k on them so I'll pick up a new set on my way home. Didn't make sense to me that starting fluid didn't even get a spudder or make the plugs wet.
Old Sep 8, 2010 | 11:58 PM
yah if you used starting fluid and it didnt even try to fire then something is off. what did you mean noid light on the sparkplug wire? i know theres noid lights for the injector and iac valve but never heard of one for spark. what is it?
Old Sep 9, 2010 | 12:10 AM
Bessette's Avatar
I call it a noid light just cause does the same thing with the spark as with the injectors. Inline spark test light. I also have a wireless spark tester you just touch to a plug wire and it uses you as a ground to light up for fast diagnostics but I should use the technical term. Sorry
Old Sep 9, 2010 | 08:20 PM
thats ok i was thinkin i need one. lol. this is a new one for me. might try checking the map, i have two cause i was having issues and ended up with an extra opti, ingnition module, map, coil, iac, tps and 02s. it was my ecu, aka main engine computer. do you have a chip in the ecu those have been known to screw the pooch to.
Old Sep 12, 2010 | 10:34 PM
Bessette's Avatar
Yea........I feel like a dumb ***.........Had someone else look at the spark while I was cranking & trusted him when he said it had a blue spark......When I looked IT WAS WHITE.........New coil & she fired right up. Thanks for the input!
STUPID MSD COIL
Old Sep 24, 2010 | 12:03 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Glad to hear it worked out.
JettMediaInc
Aug 24, 2012 06:03 PM
keithatlbertrand
Mar 29, 2010 01:19 PM
diesel210271
Jul 19, 2009 03:09 AM
fashion
Jun 19, 2009 05:15 PM
camarotodd
Feb 10, 2008 10:30 AM
