LT1/LT4 Tech 1993-1997
1997 LT1 motor rattle
Old Dec 2, 2010 | 11:13 AM
camaroboy68ss's Avatar
June 2010 ROTM
Ride of the Year 2010
Default 1997 LT1 motor rattle
my 97 camaro has 106000 miles on it now and the lt1 is all stock except for a k and n cold air intake. when ever since for a couple of hours and then your fire it up it has a little knock in it for a second then goes away. i think its a lifter bleeding off, but i dont know. if it is can i get the top end of the motor off without pulling the motor?
Old Dec 2, 2010 | 11:01 PM
yes you can. is it a tick or a knock? whats the oil pressure? what wt of oil are you using? what oil filter?
Old Dec 3, 2010 | 09:20 AM
Your lifters could be gummed/gunked up, causing the tick. Try changing to synthetic oil, as it does a better job of cleaning out (and keeping clean) the innards of the engine. Been there, done that, got results.
Old Dec 3, 2010 | 11:10 AM
June 2010 ROTM
to craby- its a little knock when i first fire the engine. i have great oil pressure. im using 10-40w oil and a fram oil filter.
to camaro69- ill give it a try the cars needing a oil change anyway right now.
Old Dec 3, 2010 | 06:29 PM
i would get rid of the fram oil filter. i think its the fram guard but i just avoid all fram.
Old Dec 4, 2010 | 08:39 AM
June 2010 ROTM
why are frams bad? ive never had any problems with them and neither has anyone else in my family. and what do you recommend for a filter?
Old Dec 4, 2010 | 05:20 PM
purolator, napa gold are good. the one fram uses a metel bypass that fails, have also read that fram filter has been known to go to pieces and plug oil passages. best way to see the difference is to cut a couple open and see.
Old Dec 5, 2010 | 01:37 AM
Make some popcorn first: http://people.msoe.edu/~yoderw/oilfi...ilfilters.html
rj44130
Jun 23, 2012 08:27 PM
kainen
Jun 18, 2010 11:39 AM
Freshcamaro
Mar 17, 2009 04:55 PM
MassholeLT1
Mar 22, 2008 09:28 PM
Beninarkansas
Dec 19, 2006 08:38 PM
