1997 LT1 motor rattle
my 97 camaro has 106000 miles on it now and the lt1 is all stock except for a k and n cold air intake. when ever since for a couple of hours and then your fire it up it has a little knock in it for a second then goes away. i think its a lifter bleeding off, but i dont know. if it is can i get the top end of the motor off without pulling the motor?
yes you can. is it a tick or a knock? whats the oil pressure? what wt of oil are you using? what oil filter?
Your lifters could be gummed/gunked up, causing the tick. Try changing to synthetic oil, as it does a better job of cleaning out (and keeping clean) the innards of the engine. Been there, done that, got results.
to craby- its a little knock when i first fire the engine. i have great oil pressure. im using 10-40w oil and a fram oil filter.
to camaro69- ill give it a try the cars needing a oil change anyway right now. |
i would get rid of the fram oil filter. i think its the fram guard but i just avoid all fram.
why are frams bad? ive never had any problems with them and neither has anyone else in my family. and what do you recommend for a filter?
purolator, napa gold are good. the one fram uses a metel bypass that fails, have also read that fram filter has been known to go to pieces and plug oil passages. best way to see the difference is to cut a couple open and see.
(Post 484054)
