02 sensor on a 96
#21
lt4weeda: If you're installing long tubes you will need to have O2 extensions. If you're soldering savvy you can just splice some wires in and re-wrap them (that's what I did), but you will need to extend the O2 wires.
#23
If you're just getting shorties you shouldn't need them since most shorty headers are designed to be able to bolt up to the stock Y pipe. Since the O2 bungs are on the very bottom of the stock manifolds you should be fine without extensions.
fuhhuayt
05-05-2011 01:04 PM
