LS Series Tech 1998-2002
Stock suspension question(s)
Old Jul 1, 2010 | 10:13 PM
bmcclz28's Avatar
Default Stock suspension question(s)
Hey Guys,
I'm new to the forum, and I'm here because I am hearing what I will say sounds like a "bottoming out" or "slight grinding" sound from the drivers side front, it happens on larger bumps or on a dirt road <--my street is under construction, i don't go off roading with my Z. I have an appointment at the dealership in a few days, and I just want to be armed with a little knowledge as to what it may or may not be, and I don't want the tech a the dealership to be like, "Oh its this, this, and that and oh yeah this is shot too". I am planning on having a friend do the work, but he has asked me to find the issue before he starts ripping things apart.
I read in another post where someone heard a similar sound but coming from the rear, a mod suggested a crack transmission mount which turned out to be it, now, in that post, the poster also said he was experiencing some rough shifts as well, I too, am having that problem ever since this "sound" issue started 2 weeks ago.
You guys rock, and I am happy to be a member of the forum!!
Old Jul 1, 2010 | 10:36 PM
could be brakes or wheel bearing. are u noticing the steering wheel pulling to the driver side? jack up that side and spin the wheel and listen for any grinding and feel if it turns smoothly.
Old Jul 2, 2010 | 07:57 AM
bmcclz28's Avatar
I will give that a try, I don't notice a lot of pulling to the drivers side, but yes it does pull sometimes. I really hope its nothing major!!!!
Old Jul 2, 2010 | 09:27 AM
stableizer or control arm bushings could be worn and in need of replacing as well. so it does it going slow but not when going a little better pace?
Old Jul 4, 2010 | 01:51 PM
libertyforall1776's Avatar
I think your shock may have come loose from the mount (maybe rust or a pothole) -- same thing happened on my RS, now I need a new passenger side strut mount, and I think the nut up-top rusted (won't know until I do the removal).
Sudduth49
General Racing/Tech
Nov 6, 2013 08:25 AM
JPrice
May 20, 2012 03:48 PM
weaz4200
Nov 28, 2009 05:58 PM
wr3ck3dm1nd
Aug 11, 2009 07:36 AM
aleksandr
Nov 13, 2007 02:25 AM
