Stiffer suspension... stock ride height
Old Aug 10, 2009 | 10:50 PM
wr3ck3dm1nd's Avatar
Default Stiffer suspension... stock ride height
So my dad has a 95' Camaro (V6). We recently took a road trip, and with passengers in the rear, and due to the offsets of his wheels, he rubs like crazy on the rear passenger side. He is stubborn and loves his wheels so those wont change. Which only leaves the suspension to be able to be changed.
My question (really his question) is, are there any spring setups out there with increased spring rates, while maintaining stock height? Are the V8 suspensions any different? Also is it possible to roll the fenders in the rear or are they fiberglass? Any help would be appreciated, Thank You~
Old Aug 10, 2009 | 11:42 PM
GMDCAMARO's Avatar
How often does he travel with passengers? Camaros only seat two you know
Does he always rub? Or just when the car is full of passengers?
Old Aug 10, 2009 | 11:44 PM
could try a adjustable panhard bar and see if centering the rearend will help. i am thinking either u have stock springs that are getting tired or it has lowering springs on it. i have wheels on my 93 that do not offset far enough to and ive had a lot of weight in the back without any problems. i then lowered the rear a little over an inch and it will rub now. fender are steel and i am planning on rolling the rear fenders before the paint job,,,, in about three years. lol. dont trust myself to get the heat right so figure ill try it just before so if i screw up its ok and well learn about it to. ill be doing some upgrades on mine in the next yr and will be looking for advice from sam at stranos. u can get air assist springs to that do not effect the ride untill they are needed. give sam a call. heres the web site cruise it and see if it interests u.
http://www.stranoparts.com/partsmain.php
i picked up a panhard bar here
http://www.spohn.net/
the double adjustable with the good bushings. works good got the rearend centered so at least both tires rub... lol not as easy though.
Old Aug 11, 2009 | 07:35 AM
welch7122's Avatar
Does any know a company making GOOD coil springs for the rear on convertible cars? I have tried 2 different brands and both were not storng enough.
Old Aug 11, 2009 | 07:36 AM
welch7122's Avatar
I mean strong enough- yeah I went to school a long time ago.
stox58
Jan 2, 2013 10:08 AM
gagger84
Nov 30, 2012 08:46 AM
sbrussell0221
Feb 28, 2012 11:42 PM
gagger84
Jan 20, 2010 09:23 AM
sewerrat
Jul 7, 2006 02:03 AM
