LS Series Tech 1998-2002
service engine light came on
Old Mar 3, 2007 | 08:52 PM
00camaro00's Avatar
Default service engine light came on
service engine light came on got it checked and read multiple misfire. I just got a custome professional tune by ed right 2 weeks ago an new plugs and wires and everything and i havent had any problems but earlier toay the light went off. So could this be a false reading?
Old Mar 3, 2007 | 09:09 PM
Default RE: service engine light came on
Clear the code, if it comes back the trouble is real.
Old Mar 4, 2007 | 10:28 PM
SSsuperdave's Avatar
could be the knock sensors starting to act up. mine did the same thing, but was a combination of knock sensors and wires rubbed bare at the passenger side rear coil bracket. that gave all kinds of trouble codes, 48 if i rember correctly.
Old Apr 24, 2007 | 06:27 PM
mcnair's Avatar
also make sure there are no ground wires loose or off, and no leaks in the air intake rubber, these little things can cause the check engine lite to come on.
Rent
Apr 22, 2013 11:08 PM
bchbmjohn9
Sep 5, 2010 11:44 PM
93CamaroGirl
Apr 27, 2007 01:15 AM
red99camaro
Apr 12, 2007 12:04 AM
eric302
Aug 19, 2005 10:58 PM
