Question about 2002 35th Anny Camaro
#31
also, i noticed my driver and passenger door leak a bit around the top of the window and the rubber seal of the T-Top portion of the roof...its not much but its enough that when i was washing her water was dripping off of the inside edge of the frame and onto the door handle/arm rest
If you spray a direct spray on the glass you will push water inside the seals. This happens to all Camaros T-top or not. As for the tops leaking, this happens all the time and there are a few posts here about fixing them. I made one that helps seal up the rear of the T-top to body connection.
Massey
#32
Oh i didn't mean the actual tops were leaking...it was just around the edges by the windows, but you explained it so =) thanks...not to find the oil leak...if there is even one...I had just washed it...so i guess that could account for the moisture under the engine (I didn't actually spray the engine but i did spray up underneath the closed hood.)
Z28 Kid
03-11-2008 02:34 PM
