LS Series Tech 1998-2002
1998 camaro
Old Feb 14, 2011 | 06:57 PM
drawe's Avatar
Default 1998 camaro
hello i recently bought a camaro with a bad engine. I put a new engine in the car now im having troubles getting it started. ive found that 5 and 2 on the coil pack are firing and the rest are not. ive change the icm and that did not make a difference can anyone help me
Old Feb 14, 2011 | 09:50 PM
try moving the coils around and see if the spark follows, if so you have some bad coils. if not then you have bad connections or wires.
Old Feb 15, 2011 | 12:22 PM
drawe's Avatar
i tried moving the coils around the spark stayed with 5 and2 i changed the icm there are new plug wires and the connections are all good anymore ideals
Old Feb 15, 2011 | 12:53 PM
woh thats strange. check the reluctor wheel and make sure its not damged. im not real up on the ls system so i would be guessing on were it is. lol should be on the crankshaft.
jamguitarist91
Jan 14, 2010 12:21 PM
racertay
Feb 25, 2008 09:28 PM
camroadrenaline
Jul 4, 2007 02:36 PM
Jgravot
LS Series Tech
May 1, 2007 10:28 PM
