LS Series Tech 1998-2002
Oil leak
Old Mar 31, 2017 | 11:06 PM
Ennisdavis23's Avatar
Default Oil leak
I used the uv dye. Not coming from slot in bell housing. Its dripping from the starter bolt up high on engine. No oil from heads up. Drips down the joint between engine and belhousing. Some of the cross main bolts look wet but this starter area is dripping bad. Any ideas?
Old Apr 2, 2017 | 12:14 AM
oil pressure sensor/switch, common leak spot, sensor fails and leaks. otherwise i would look at the rear intake seal but i dont hear much on them leaking in the ls1
CamBigCat
May 28, 2016 02:04 PM
Jelz28
Jul 18, 2012 06:01 PM
cazador64
Mar 13, 2006 01:22 AM
