LS Series Tech 1998-2002
Noisy pulley?
Old Jan 23, 2011 | 02:14 PM
supersmoothpunk's Avatar
Default Noisy pulley?
I was out in my 99 Camaro today that I`v owned for a week and it started making a noise. It sounded like one of the pulleys. I went into a store and it carried on after I had re started it but stopped again after a few minutes. After about 20 minutes of driving I came into heavy traffic and it started again. It seems to start when I slow down for a minute or so and clear once I start moving.
Old Jan 23, 2011 | 04:27 PM
Could be:
Worn serpentine belt
Bad/noisy idler pulley bearing
Bad idler pulley bearing causing belt mis-alignment
Bad alternator bearings
Worn power steering pump
The A/C clutch is shot
Your best bet would be to remove your belt and give all of your pulleys a twirl by hand. Listen for noise, and feel for wear or slop.
Old Jan 24, 2011 | 09:48 AM
Nick B's Avatar
Check the idler and tensioner and the bearings in both. I've had one go out on me and shred a belt.
Old Jan 24, 2011 | 01:13 PM
Massey's Avatar
Remember the LS1 Camaro's have 2 belts and the 3.8L's have only one.
Massey
808SS
May 4, 2013 04:45 AM
nnewquist
Apr 5, 2012 07:55 PM
1998camarossclone
Sep 26, 2010 08:41 PM
dazed&confused
Dec 17, 2009 05:24 PM
PUTT_PUTT_PASS
Sep 16, 2009 09:17 PM
