LS Series Tech 1998-2002
'02 Z28 Service Engine Soon Light
Old Nov 17, 2010 | 11:51 AM
arichard416's Avatar
Default '02 Z28 Service Engine Soon Light
I have a 2002 6-speed Z-28 with no mods other than a flowmaster exhaust. The SES light came on when I got stuck driving through the rain. Went to autozone and the code came up as P1416 and listed reasons as: 1)Air pump electrical circuit fault 2)Blocked air system 3)Failed air pump. It has been rainy and gross up here in Mass for a little while but today is nice and the light turned off. The service manual says that water in a connection can make the SES light turn on. My question is; should I leave her alone or replace the air pump?
Thanks,
Andrew
Old Jan 7, 2011 | 02:56 PM
Bouigha123's Avatar
As the saying goes if it aint broke don't fix it; if the car is runing fine and the light is not on then i would not worry about it
Old Jan 8, 2011 | 05:52 AM
Massey's Avatar
Leave it alone. When I read codes for my cusomers I usually clear them and if the code does not come on after I restart the engine I tell them to wait and see if it comes back. If so then take the problem serious. So if you get the same code again then look at the connections, pump, hoses and all that good stuff.
Massey
Old Jan 8, 2011 | 12:32 PM
auto's Avatar
that pump is behind the foglight area, water can go in there easy if your headlamps arent lined up right with your bumper right. ^ +1 clear it and drive
Old Jan 31, 2011 | 05:43 PM
libertyforall1776's Avatar
Air Pump is emisions-only related... no other benefit -- many remove them when installing headers.
Rent
Apr 22, 2013 11:08 PM
bchbmjohn9
Sep 5, 2010 11:44 PM
93CamaroGirl
Apr 27, 2007 01:15 AM
red99camaro
Apr 12, 2007 12:04 AM
eric302
Aug 19, 2005 10:58 PM
