LT1/LT4 Tech 1993-1997
noisy rockers
Old Dec 16, 2009 | 05:47 PM
dazed&confused's Avatar
Default noisy rockers
i a tapping noise coming from the valve cover it sounds like rocker arms is there any way to adjust them. I got a 95z with lt4 hot cam and 1.6 rocker.
Also what is needed to fix this.
Old Dec 16, 2009 | 06:57 PM
so u have a lt1 with 1.6 roller rockers? u need to take the cover off and make sure it hasnt come lose. to start with whats the oil pressure cold and at running temp? what kind of oil filter are u useing? how many miles on the car? how about some history on the motor.
Old Dec 17, 2009 | 01:01 AM
the oil pressure cold is right above half mark running is right at the half mark. I'm using a stp oil filter. the motor was rebuilt in 2005 and has about 10k miles. it's a 327 block with lt4 hot cam 1.6 rockers and basic bolts on intake exhaust headers tb.
Old Dec 17, 2009 | 04:34 AM
yes the lifters can be adjusted, could be that rocker is coming lose and needs to be reset or u could have a lifter that has went bad.
Old Dec 17, 2009 | 04:20 PM
how is this done
Old Dec 17, 2009 | 05:24 PM
whammer3024's Avatar
ROTM Winner
since you asked for help...here ya go! hope this helps ya!
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
808SS
May 4, 2013 04:45 AM
nnewquist
Apr 5, 2012 07:55 PM
1998camarossclone
Sep 26, 2010 08:41 PM
PUTT_PUTT_PASS
Sep 16, 2009 09:17 PM
camarokid1968ss
Apr 23, 2006 12:34 PM
