LS Series Tech 1998-2002
Headlights
Old Oct 6, 2008 | 12:59 PM
MidnightLS1's Avatar
Default Headlights
My headlights have that fogged over look to them, is there anyway to fix that or do i just have to buy a new set? If so, where is the cheapest place to order them??
Old Oct 6, 2008 | 01:59 PM
02StanGT's Avatar
Default RE: Headlights
They have some headlight fix-it stuff at WalMart.
Old Oct 6, 2008 | 02:32 PM
Have you heard if it works very well? Or have you used it yourself?
Old Oct 6, 2008 | 03:51 PM
bill126's Avatar
i've heard of kits for $20 or so from walmart i believe.. As far as i know they come with a couple different grits of sandpaper, and some kind of polish/protect stuff.. but, i've never seen them. I'm pretty sure you can just sand it down with some sandpaper, then sand it a couple ore times (or whatever's necessary) with a higher grit sandpaper each time. Then just buff the living hell out of it with some polish.. I'm guessing Maguires PlasticX would work? I'm not sure what would be a good grit sandpaper to start with though..
Old Oct 8, 2008 | 12:11 AM
evilkal's Avatar
I did this with my car. I used 1000 to get the haze off, 1500, then 2000. All wet sanded. Be prepared to use a little muscle lol. Then use Meguiar's PlastX to clear them up... Then use metal polish to make em shine =D
Old Oct 8, 2008 | 08:53 AM
Where is a good article on the easiest way to remove the headlights?
Old Oct 8, 2008 | 11:24 PM
bill126's Avatar
what kinda metal polish,evilkal? Mine are nice and clean, they're just starting to develop some cracking though... any suggestions? I have some PlasticX, just haven't had the chance to use it.
tim dawson
Feb 25, 2019 02:24 PM
Pig Hunter
Dec 7, 2010 10:51 PM
cocanut
Oct 31, 2010 07:37 AM
JordanN
Aug 8, 2010 07:06 AM
Skippysnax
Apr 20, 2008 07:28 PM
