'95 Headlights
Old Dec 4, 2010 | 05:41 PM
Pig Hunter's Avatar
Default '95 Headlights
Dumb question #2483
When the brights are on are the low beams suppose to be on also? All four lights?
Old Dec 4, 2010 | 05:42 PM
Chaotic94's Avatar
September 2011 ROTM
Uhm yes.
Old Dec 4, 2010 | 06:11 PM
Pig Hunter's Avatar
Like I said, dumb fing question, but thanks for the quick answer. Mine are stuck on high beam, just wanted to make sure that was the only problem. I know how to fix the "stuck" problem.
Old Dec 4, 2010 | 06:36 PM
Chaotic94's Avatar
September 2011 ROTM
Does your switch click when you try to switch them off?
Old Dec 4, 2010 | 06:44 PM
Pig Hunter's Avatar
No, and I've tried moving the column up and down while moving the stick. Either the rod isn't hitting the switch, its totally worn out or it's gone. Gonna take it apart tomorrow and see which it is, too damn cold out there right now.
Old Dec 4, 2010 | 06:47 PM
Chaotic94's Avatar
September 2011 ROTM
The rod could be bent. Also you can adjust those by taking off the panel below the steering wheel and bending it. Take off the little plastic piece covering the switch and you can adjust it there too.
Old Dec 4, 2010 | 06:52 PM
Pig Hunter's Avatar
I did not know that, thanks, I'll try to click the switch manually 1st, if it it works I'll see what I need to do to adjust it.
Old Dec 4, 2010 | 06:56 PM
Chaotic94's Avatar
September 2011 ROTM
yeah that plastic cover that covers your switch just pops off and you can adjust it there.
Old Dec 4, 2010 | 08:22 PM
make sure the base that the lever uses is not broken. when i took the cover off i could see a crack in mine and it let the lever base move so the lever was not moving the arm far enough to click the switch.
Old Dec 7, 2010 | 10:51 PM
Pig Hunter's Avatar
Bad switch....
tim dawson
Feb 25, 2019 02:24 PM
LT1ChevyBoy
Dec 30, 2010 06:43 AM
cocanut
Oct 31, 2010 07:37 AM
JordanN
Aug 8, 2010 07:06 AM
Skippysnax
Apr 20, 2008 07:28 PM
