1998 camaro 3.8 intake help
Old Mar 2, 2010 | 01:20 PM
ronfl04's Avatar
Angry 1998 camaro 3.8 intake help
(intake manifold) i took off the upper got all the bolts i can find out and it is loose on passengers side but on drivers side it seems to still be held by a bolt or something. is there some thing i'm missing? i have looked every where.
any advice would be very app.
Old Mar 2, 2010 | 04:23 PM
Failed Devices's Avatar
You are trying to remove the intake correct? Give these a look over:
http://www.installuniversity.com/ins...am_air_mod.htm
http://www.4thfbody.com/forums/showthread.php?p=11
Did you unscrew the metal clasp that holds the rubber hose from the intake to the throttle body?
Old Mar 2, 2010 | 04:32 PM
ronfl04's Avatar
i need to get intake manifold off. sorry didn't make it clear.
Old Mar 3, 2010 | 04:46 PM
I think there is one under the thermostate. You can go into the 4th gen section and grab the parts manual. It should have an exploded view.
Old Mar 4, 2010 | 04:01 PM
osduck5's Avatar
Gorn is right but it is one of the two bolts that hold down the thermo housing. One is longer than the other and holds down the front of the plenum unless both are removed.
Old Mar 5, 2010 | 11:29 AM
ronfl04's Avatar
Default thanks guys
we got it off
carid
Vendor Special Buys
Jan 20, 2015 07:08 AM
Steve1972
Jun 5, 2011 02:05 PM
Steve1972
Jun 2, 2011 03:16 PM
derek5stone2006
Sep 10, 2009 02:25 PM
guids10
May 16, 2007 09:48 PM
