2002 3.8 Camaro Rough Idle and Sputtering under load
Old Yesterday | 01:58 PM
Lacyj1983's Avatar
Unhappy 2002 3.8 Camaro Rough Idle and Sputtering under load
Recently my everyday driver started having issues with sputtering when taking off. Immediately thought it was bad gas or clogged fuel filter. Changed fuel filter and fuel pump and problem is still there. Started to check elsewhere and noticed that my air filter wasn't put back in after my last oil change which would have been a little over a month ago. I cleaned throttle body and MAF sensor and problem is still there. I'm no mechanic so I'm stuck as to what to look at next. As soon as you crank it the service engine soon light starts flashing and you get the rough idle. It will clear up some while driving but if you put it under a load, it starts back with the flashing service engine soon light and the sputtering.
illestz28
09-07-2011 10:01 AM
Jaykob
70-81 V8 Tech
04-03-2011 12:54 PM
chewybacca11
08-23-2010 06:20 PM
SurpriseIroc
82-92 V8 Tech
11-17-2008 03:32 PM
oakwood69
07-09-2008 09:56 AM
Quick Reply: 2002 3.8 Camaro Rough Idle and Sputtering under load
