rough idle need help
Old Jul 2, 2008 | 08:49 PM
oakwood69's Avatar
Default rough idle need help
when at idle the engine shakes every 5 seconds or so not terrible jus a little shake but runs fine beside but i bet it could run better
ive replaced fuel pump, fuel filter, new platnium plugs, air filter im stumped any one have an idea?
Old Jul 6, 2008 | 01:18 AM
Justin_97_CamaroSS's Avatar
Default RE: rough idle need help
could be opiti spark or befor you change that check your FPR Mine was out and my car would idol funny and sound like a knock in the top of the engine.
Old Jul 7, 2008 | 08:37 PM
69 to 97 Camaro fam's Avatar
what's the FPR? IS that Fuel pressure regulator?>
Old Jul 8, 2008 | 01:39 AM
95slvrZ28's Avatar
Check the IAC, are you getting any check engine codes?
Old Jul 8, 2008 | 02:11 AM
yes
I A C ?? help me out
Old Jul 8, 2008 | 02:13 AM
oh ya it might be good idea to check all your vacuum lines to.
Old Jul 8, 2008 | 03:04 AM
95slvrZ28's Avatar
IAC-Idle Air Control
Old Jul 8, 2008 | 11:24 PM
oakwood69's Avatar
good **** thanks
Old Jul 9, 2008 | 09:56 AM
camaro_burns_all's Avatar
VIP member
Check your throttle body is not clogged. Btw Your IAC should be located on your throtte body
csmiddy
67-69 V8 Tech
Dec 9, 2012 10:12 PM
husker_camaro95
Feb 16, 2011 07:38 AM
CJ51974
Jun 1, 2009 08:59 PM
foxtrot51
Jul 23, 2007 08:38 PM
BOSS ROC
Mar 9, 2006 01:17 AM
